Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
Charging port won't work
my charging port will not work anymore. i have tried cleaning it our with compressed air and it still will not work
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Slade,
Assuming you've already tried a different charger and cable, then you're pretty much down to having to replace the charging port. It's not at all uncommon for the pins inside to get bent or damaged causing the port to fail. The repair itself is fairly straight-forward for an iPhone. Unfortunately iFixit hasn't gotten a chance to create that guide yet, but the Spanish site Nadie Me Llama Gallina has just what you need.
Manuals / Apple iPhone 13 / Charging flex
You can buy a good quality replacement part right here on iFixit though. It comes in various colors so the inside of the port matches your phone case, although in practice any color will work; it's strictly cosmetic.
iPhone 13 Lightning Connector Assembly
Don't forget to pick up a sheet of precut adhesive to glue the screen back on when you're done! I usually get a couple - they're easy to mess up and very unforgiving so it's a good idea to have a spare on hand just in case.
Good luck; let us know how it goes!
Immagine Replace a lightning connector assembly compatible with an iPhone 13. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-03154.
Prodotto
$49.99
Punteggio 2
Aggiungi la tua risposta
Slade Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 119
Tutti i Tempi: 1,827
