Side of removable battery: what is the screw type and size?
Is that a Torx 1 or 2 maybe? I have the expanding battery symptom, thought I'd have a look inside. ;) Just want to make sure I order the right screwdriver.
Questa è una buona domanda?
Macbook 1181 removable battery: torx screws (qty 10)
I can remove these screws using 3 sizes of torx screwdrivers
- T4
- T5
- T6
T5 seems to be the one who's got the better grip. If you want to be sure bring your battery in a hardware store and try the screwdrivers.
+ and I thought those were tri-lobe 922-9249 or 922-9515 ;-) thanks.
Thanks lemerise!
I thought I'd try the only similar size screwdriver I had, the MacBook Air pentalobe screwdriver, and it worked. All screws removed no problem. Lucky ;)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,357
