Why is my phone's turbo charge doesn't function anymore?
battery drains fast and overheats.
Questa è una buona domanda?
Make sure your charger and cable are still good and provide turbo charge. Also if your battery drains fast you should replace it and a bad battery also could take less power at charging, so that's why it doesn't turbo charge. Also try to clean your charging cable and port with a toothbrush with some alcohol on it. Be careful put a small amount of alcohol on your toothbrush and not directly to the port and before plug your charger on, make sure it is dried.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 99
