Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Trackpad jumps like crazy. Impossible to use.
Hello,
Some months ago the trackpad started to be less responsive. With the time, the problem got worse. Now, it is completely wild, it jumps around and clicks everything without touching it. Trying to control it is just impossible. I have to use it with an external mouse connected all the time.
I have tried almost everything:
The battery is not the problem as the hardware test shows it is ok and it is not bulging, totally plain.
I replaced the trackpad for another one. Nothing went better.
I also reinstalled Lion and reset the complete system after saving all my data and apps into an external disc.
Any thoughts?
Thanks in advance.
P.S: I upgraded the RAM from 2GB to 4GB. The memories were the original ones from a MacBook Pro.
Questa è una buona domanda?
Punteggio 0
1 Commento
I called Lenovo (79.95) for them to do nothing and I still have the same problem.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like the trackpad cable - it passes through a slot in case which can act like a guillotine crimping or damaging the cable as you hammer keys on the case. Some have had luck wrapping the cable with a small piece of paper or tape to protect and stiffen it.
Good Luck,
If this answer was helpful please remember to return and mark it Accepted.
Punteggio 0
Aggiungi la tua risposta
aitordelapera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,172
