Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Why iPhone 3GS stuck to apple logo after replacing glass digitizer?
hello I have replaced my iphone 3gs glass digitizer but after that phone is stuck to apple logo i tried to install ios 5.0.1 so many times it installs but after completion it stuck to apple logo. i dont understand the problem it is definitely some hardware issue. kindly help
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
replace the proximity sensors, it will be resolved. For being sure first disconnect connector 3 (number3) and only connect lcd and glass connector if iphone power on normal replace proximity sensors (number 3 flex cable) .
Punteggio 0
3 Commenti:
Well bugger me, it worked. After upgrading and downgrading, restoring, jailbraking with every kind of sn0w there is, it was the proximity sensor. Many thanks, I was about to give up.
da
I Loooooooooooooooooooooooooooove you. Thanks
Best rgds
Peter
da
This works ,I thought it wouldn't because honesty it doesn't make sense ,all I did was unplug the #3 ribbon and it went pass the apple logo
da
Amazing! This worked for me as well; however, now the ear speaker doesn't work. Does the same ribbon control both the speaker and the proximity sensor?
Punteggio 0
It worked perfectly. I tried everything else but this was so simple by removing number 3 connector.
Thank you
Punteggio 0
Aggiungi la tua risposta
Amol sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,994
