Salta al contenuto principale
Il telefono è dotato di un display touchscreen da 6,50 pollici con una risoluzione di 720x1600 pixel, una densità di pixel di 269 pixel per pollice (ppi) e un rapporto d'aspetto di 20:9. L'Oppo A53 2020 è alimentato da un processore octa-core Qualcomm Snapdragon 460 da 1,8 GHz. È dotato di 4 GB di RAM.
My charging port is not working
my oppo a53s charging port has an issue the charger cannot fully get inside
Questa è una buona domanda?
Punteggio 21
13 Commenti
USB port dry and clean and reset phone ka masge a raha ha bar bar
da Condividi
Charging not working
da Condividi
@prajju same steps as in my original answer.
da Condividi
Charging problam
da Condividi
@oppoa5325446 same fix as the original answer unless you have other issues that you have not described.
da Condividi
Mostra 8 altri commenti
Aggiungi un commento
2 Risposte
Soluzione prescelta
@vitin40128 check the port for any debris or bend contacts. If cleaning it or if the contacts are broken, you will need to replace it. Luckily the charging port is soldered to a charging board. It will be much easier to just change the complete board. You are looking for something like this
iFixit doesn't yet have a guide for this. Use something like this video to get this repair done.
While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Punteggio 2
5 Commenti:
Charge is slow. Charge is slow. Charging is delayed
da Condividi
Change charging point
da Condividi
da Condividi
@ladabeshra you did not provide enough information to actually help you. I would suggest the same thing as in my original answer.
da Condividi
Máy bị vào nước sạc thì nhận đc 1s là ko vào nữa
da Condividi
Punteggio 1
Aggiungi la tua risposta
vitin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 21
Ultimi 30 giorni: 63
Tutti i Tempi: 4,188
