Salta al contenuto principale
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460).
24 Domande Visualizza tutte
iPad is bent and screen cracked. I’m scared to bend it back
I want to replace the screen but with it being slightly bent, the new screen wouldn’t go on correctly.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I have repaired many iPads in similar condition before and the metal is actually really easy to bend back in place. I would definitely remove the motherboard and battery very carefully before attempting to bend it back though and should be left to a professional if you haven't disassembled an iPad before. Backup your data before just in case. Once the motherboard and battery are removed then the aluminum shell is easy to bend back into its original shape.
Punteggio 1
Aggiungi la tua risposta
Kai sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 39
Tutti i Tempi: 145
