Replacing Glass Digitizer Hot Glue Gun?
Hi,
I'm changing my first iPad 2 digitizer tomorrow, and would like to know if using a glue gun to reattach the screen is a good idea. I don't have much experience with a glue gun, but I don't see it being a problem.
Any advice would be great, thanks in advance.
Questa è una buona domanda?
3 Commenti
Thanks for the replies.
I went with the 3M adhesive strips,looks like its done the job.
One question though. Does the strips need time to set?? I've seen some videos on youtube and some say to set the iPad down and put something of weight on the back and let it set for 24hrs.
Is this necessary?
da Matthew
They really Should be at full strength immediately after putting some pressure on the digi screen. But I know what you mean, it kinda seems like they don't quite hold as well as the factory strips. Or at least that's what I thought. But they do hold good enough I think. I have thought about adding some weight too but I guess if you don't use too much you should be ok..sometimes I'll push on my screen just to make sure it's making all the contact it can to the strips..
So, did you have any trouble with the wifi tearing or pulling off or anything?
da Chuck sawyer
I had a few problems to be honest lol. The wifi tore a little on one of the two screws. But it seems to work fine, and I also nicked the power/volume ribbon, it didnt look like I broke any connection but when I put it back together the power button didnt work, so I had to change that as well. Very tedious job changing that. Oh well, atleast I know for next time.
da Matthew
