Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
Doubting if the MBP screws are Phillips, JIS or Frearson
Hi
I'm going to open my MBP because part of the screen does not look, sometimes is black, other times it flashes. Sometimes even display properly.
I think is the LVDS cable.
But I have to be sure what kind of screws are.
The guide says I need Phillips #00 screwdriver, but they didn't seem it. Big image MBP Screw (Steep 9, LCD Replacement)
I think is JIS (Japanese Industrial Standard) or Reed and Prince (also called Frearson)
Phillips no always is phillips
Phillips Screw head
Phillips vs Frearson
Phillips vs JIS
iFixit sells JIS Driver set
It said:
"JIS screws are not designed to "cam-out" or strip the head when overtightened like a Phillips screw, and can be damaged if a Phillips driver is used. JIS drivers can be used in both JIS and Phillips screws with no damage"
What do you think?
Immagine JIS Driver Set
Prodotto
JIS Driver Set
$19.99
Questa è una buona domanda?
Punteggio 2
1 Commento
I don't really care what type of screw head is on the MacPro. I need to remove the screws to replace screen and I just want to know where to go to get a driver that works. I bought the set of drivers recommended for screen removal /replacement and none in the set are small enough. I just want someone to tell me what will work and where can I get one, i.e., Rat Shack, etc.. Any ideas?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This is very nice information and I may order a set of the JIS drivers but have never needed them when working on a Mac. What exactly is your question?
Punteggio 4
4 Commenti:
Hi, thanks for your reply.
I want to know what kind of screws has the MacBook Pro.
I have to buy screwdrivers to open my MacBook Pro, so I want to buy the correct screwdrivers.
If screw isn't phillips, and I use a phillips screwdriver will most probably I will open the MBP, but it may damage the screw head.
Have you had any problems opening Mac?
Did damaged the screws head?
Thanks!
P.S: Other photo: http://i280.photobucket.com/albums/kk182...
da
I've opened a lot of Mac Books. The main problem on some has been with the Pentalobe screws and not having a 000.
da
Ok, may be you are right and you didn't have problems, but i am still thinking that screws are not phillips.
What do you think?
da
I agree with Mayer -- the problem most often is is just not having a small enough screwdriver. Whether or not they are technically phillips, I've never had a problem removing those screws with a phillips screwdriver. If these screws required a different type of screwdriver, we would have all discovered that years ago. Interesting information though, and I would be curious to try the JIS drivers.
da
Aggiungi la tua risposta
OceanicSix sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,589
