OWC Aura Pro X2 SSD won't fit
Trying to replace the SSD with the Aura iFixit recommends but it doesn't go down far enough to replace the screw.
Update (05/11/23)
Questa è una buona domanda?
Can you post some pics so we can see things. Show us the screw location with the drive in place. A second looking down into the socket.
updated with photos
@lumivuohi - I can’t tell for sure as I can’t see deeply enough T into the slot to see if you have a bent pin blocking things.
Assuming it’s not then you need to apply a tad more pressure sliding the SSD into the slot. Make sure you don’t lift it up as that could damage things.
Hint! There is a key way in the connector the gap you see now needs to almost be gone when fully inserted.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 46
