Laptop Won't Power On Without Charger
My laptop won't power on unless the charger is plugged in. Is this a battery issue? How will I fix this?
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 29
Battery could have gotten disconnected, definitely check that first.
da Craig Sampson
@csam15 I've checked the make sure the battery is properly seated, and removed it before re-inserting it more than once.
da Russell Repair Co.
Does the battery have any output? Just did a quick google search it should be about 15v
da Craig Sampson
@csam15 I don't know, I don't have a circuit tester
That would be the logical next step, if the battery is plugged in correctly it is possible it could be dead. If you don't have access to a multimeter you might want to think about buying a new battery
da Craig Sampson
Mostra 1 altro commento
