Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
376 Domande Visualizza tutte
My iMac 2390 won’t turn on
My sons 2010 imac 27” hasn’t been turned on in 5 years. Worked before that. I turned it on today and nothing turned on. I removed the lcd screen to gain visual access to th diagnostic LEDs and saw the number 1 LED was on. I pushed the power button and the number 2 LED blinked and then both 1 and 2 shut off. I removed power and repeated only this time I shorted the power switch on the board and got the same result.
I tried holding the power button for 1 min with and without power cord and no change.
Given that it worked before not using it it for an extended period I’d be surprised if the power supply board went bad but of course it’s possible.
Anything else I should try?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@emdoller yes, that sounds like a bad power supply. Check the cables to the logic board. Make sure that they are properly connected etc. Also, check the power supply. I would not bet surprised to find some degraded or even leaky capacitors. After that you can try and measure some voltages.
If unsure, you can always post some pictures of your PSU with your Question. That way we can see what you see. Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
Emdoller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 13
