Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
iPod touch 4G sleep button broken. why isn't volume button?
Hi I surprisingly successfully changed my iPod touch 4th Generation screen by myself but when I tried to turn it back on, I found the sleep button was broken so I had to put it in the charger for a second.
I don't want to have to buy a new part or majorly open up my iPod again so what I'm wondering is, is the cable of the part ripped or is it an easily solved problem. From what I understand, the sleep button and the volume buttons are one part so surely if a cable was torn, they would both not be working.
Questa è una buona domanda?
Punteggio -1
1 Commento
same thing happened to me have you fixed it?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I had run into the same issue and i figured it out!!!!
It was the metal spudger tool I was using. I noticed that ever since i bought the set from here I had the same problem with the lock button not working but the volume still functioning. I had never once had that problem before, and i have done a lot of these. I did some experimenting with iPods that were under warranty still and used the tool more and more sparingly. I believe the exact issue came from when I was removing the copper tape that secures the digitizer ribbon. When I would repair the iPod not using that tool at all except to remove that tape I still had that issue. I believe it is the metal conductivity. Solution, use screwdriver with a rubber handle.
Immagine Metal Spudger Set
Prodotto
Metal Spudger Set
$7.99
Punteggio 0
My sleep button has now stopped working and I've been told bye the techs at radio shack said that they stop working because of over use.
Punteggio 0
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,626
