Removing battery for USB only usage?
Is possible to simply remove the battery inside PTH-660? In a studio setup, it is not really needed. USB is better!
Questa è una buona domanda?
You can remove the battery but you'll need a soldering iron. You can follow this ifixit guide here.
OK, thanks, but removing the battery puts the tablet in "USB Only" mode?
Nevermind the question.
I removed the battery and I can confirm: the tablet Works Without the battery. Just a brief message that the battery il low, but after that IT WORKS
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 505
