Salta al contenuto principale
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
42 Domande Visualizza tutte
My screen fell and became black, what should I do?
I have Samsung galaxy tab a 10.1 (2019)
The screen glue that kept screen with it was weakened somehow and screen was coming out multiple times but since it was not a big deal as everything seems to work perfectly I ignored it.. Until today My screen came out and fell on my table ( u can assume position of tab like distance to be like 20cm touched with the surface with angle of 80° approx.)
I don't know how much damage it did internally but what I can observe was the ribbon/ flex cable or whatever you call that cable came out of screen
I panicked and tried to put that back and black screen of pixels which glow a bit white on ends showed indicating that the screen was working
I repeated the same process by unplugging and re-plugging the cable again and again then suddenly I noticed drastic heat or overheating in cord and when connected to screen, In screen as well, I was panicked again and removed it again and repeated same process after sometime...
Note that there is no physical sign of broken ribbon or screen
and now I can see nothing is working either plugged or unplugged But i can hear sound by checking by my Bluetooth speaker indicating that its on
Also Bcz of some reason I cannot go to a repair shop or buy some new replacement for it
Can you please help me in fixing it myself at home???
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@helpme97578 going by your description, this sounds typical for a broken screen (internally not on the outside). You will have to replace it. Samsung Galaxy Tab A (2019) Screen Replacement
Punteggio 0
Aggiungi la tua risposta
Help_Me sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 98
