My iPhone Doesn't charge
I Plugged my iphone with a wall charger, but it seams like the plug on wall had something wrong and it damage something in my logic board, and i don't know what to do. i took it to apple store and they told me to go someplace where they can fix it, and well, i discovered that it's not the (port-microphone-speaker) and it's not the battery and i belive is the port in the logic board where you connect the port-speaker to the logic board.
Questa è una buona domanda?
7 Commenti
What has led you to believe that its the logic board and not other parts? Does the phone still act normally except for charging? Did you find burnt spots on the logic board? Tell us more so we can help you.
da Phillip Takahashi
I belive it was the logic board becuase i did a test with another iphone 3G and my logic board was working fine, except for charging ( not even conected to wall plug or the computer) and i did test my battery too and it was charging on the other iphone.
da Josh Rose
It's not the dock connector becuase i forgot to mention that i bought a new one and it was working fine in the other iphone that i used to make the tests
da Josh Rose
And what if the problem was the fuses, then what should i do ?
da Josh Rose
You can try and replace those, or bridge them from one point to the next to see if that if that is what causes your problem.
da oldturkey03
Mostra altri 2 commenti
