How to speed up 2dsxl performance?
I had my nintendo 2dsxl about 6 years now and i noticed this past year it started slowing down when i would go to power it on, any way to fix this?
Questa è una buona domanda?
Any chance you also started using a bigger sd card? The bigger the card, the longer the system takes to boot. There's not much you can do to improve performance that I know of, but Luma3DS does have some options that might be what you're looking for, though that requires installing CFW. If you decide to, 3ds.hacks.guide is the only guide you should be using
Yea I recently modded it and i'm using a 64gb SD card, I honestly wasn't expecting it to affect the start up but yea now thinking about it that makes perfect sense, and to check out those options do i look through luma3ds on my computer or right through the FBI application on the 2dsxl?
@brendandincher neither, they're in luma's config menu. I think the ones you want are "New 3DS CPU"
and possibly "Redirect app. syscore threads to core2"
ok, sounds good, thank you!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 334
