What are you trying to achieve? An update of your IOS, a restore, or an unlock?
Error 40 indicates a "Hacktivation" bug in an early Sn0wbreeze release version 2.0.1. If yes then it was fixed in 2.0.2.
If you are attempting to restore, have you tried using iReb, either as a standalone app or within Sn0wbreeze or Redsn0w to put your phone into a Pwned state for itunes?
Direct link to iReb r5 (New Version)
http://downloads.ih8sn0w.com/iREB-r5.zip
Have you made changes to your HOSTS file? If yes, did you make it "Read Only" after change?
Let Tiny Umbrella put your phone into Recovery mode instead of DFU. It will display this on screen.
I hope this gives you some direction.
Or have a look at this link for future iTunes error solutions. It is a more concise source for the "TRUE" meaning of all iTunes errors.
http://theiphonewiki.com/wiki/index.php?...
Just update your phone to the latest IOS 5.0.1 now before apple release 5.1. Jailbreaking has been solved for all iPhones and iPads.
Good you have made progress, don't give up now. Error 1601 is caused when iTunes recognizes a customised IPSW file. So what you need to perform first is while your phone is in DFU mode and connected to your PC run iREB-r4
Download from here
http://dl.dropbox.com/u/55495998/iREB-r4...
once run press the corresponding button for your phone. So you would press 3G,
and then iREB will put your phone into a PWNED state. You should see the same screens as in my screenshots below. The only difference is that I was using my iPhone 4 and you have a 3G.
This will make "decieve" iTunes into allowing the installation of a modified IPSW.
If iTunes throws the same error, then run iREB again.
Good luck.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Error 40
how do i fix it please help
da mark
