Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
67 Domande Visualizza tutte
Wifi Greyed out and bluetooth
Hello, I got this phone in repair today it had already had the screen replaced on it before working on it the screen was an Aftermarket LCD not OLED I am thinking that the screen shorted out the board causing the wifi not to work anymore. Anyways I tried a new antenna and still greyed out anyone fixes this issue or know what I should do next or is it SOL?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
is the WIFI not working since it crashed? If so, it could be a problem with the motherboard. You have to separate the motherboard first. maybe the pin is disconnected
Punteggio 0
Check it’s on the latest update. Also if there is a security app on the phone remove it. I had a phone in with the same issue. They had some security app that had disabled the connections, when I removed it all the connections came back on straight away. If it needs updated you’ll need to hook it up to a computer.
Punteggio 0
1 Commento:
The phone has been factory reset
da
Most likely cracked or torn pads on the interposer board or the Wi-Fi IC. You will need to separate the boards and check the pads between the boards before taking diode measurements of the Wi-Fi IC.
Punteggio 0
Aggiungi la tua risposta
Mark D Schlossman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 163
Tutti i Tempi: 717
