Salta al contenuto principale
Smaller brother of 300 in 6cy coupe.
While car in d, car doesn't move, and rpm raise
When I put gear in drive, the car doesn't move and the rpm meter goes up
Update (01/29/2023)
While in reverse, it work but d-1 and 2, no. Rpm meter raises when I accelerate. Year of car is 2014 chryselor 200.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
@cudang how about R and 1 and 2? What year is yours?
da
Reverse work, but d1 and 2 doesn’t. And the year is 2014 chryselor 200
da
Aggiungi un commento
1 Risposta
Chrysler is somewhat prone to bad transmissions, and this is usually one of the symptoms of a bad tranny with them. However, this is NOT cheap so you do want to do a proper diagnosis.
What I would look at first is the range sensor and see if there's an issue with one of the solenoids first, but this usually requires a high end scan tool like an Autel used by a mechanic unless you can find one for $150-200 (maybe $250) with manufacturer specific diagnostic testing. Try something like this: INNOVA-CarScan-Pro-5210, othwerwise you will need a scan tool like this: FOXWELL NT624
Punteggio 0
Aggiungi la tua risposta
Danny sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 58
Tutti i Tempi: 533
