Salta al contenuto principale
Xbox One S, progettata da Microsoft Corporation, è stata rilasciata ad agosto 2016. Xbox One S è una riprogettazione di Xbox One.
387 Domande Visualizza tutte
No sign of life.
Xbox one S has no sign off life. Have tried to change power supply and used different leads and sockets etc. any suggestions?
Update (01/25/2023)
I forgot to say, it started smoking plugged in, on replacing the power supply the smoke came back
Questa è una buona domanda?
Punteggio 0
8 Commenti
Frankie Vaughan smoking electronics is never a good sign. You replaced the power supply and it smoked again? Can you let us know where or what smoked? Post some good pictures of your PSU and your main board etc. with your QUESTION. That way we can see what you see. IF a new PSU went up in smoke, something is shortening it out and that would most likely come from the main board. Aggiungere immagini ad una domanda
da
To be fair, I didn’t even look. I ran up to grab my phone. As I came down it was smoking😬. Just quickly unplugged it as I was working in a wooden outer building😂. I have stripped the disc drive, power supply, hard drive and fan and can’t see any signs of damage. Must have been the underside. To be fair I think I’m going to just give up as that was too close and I don’t have much experience with micro soldering. Thanks though!
da
@Frankie Vaughan you sure? Don't even want to check? :-) Sounds like you already have it mostly apart. All it takes for now are a couple of good pictures. Remember: REPAIR IS WAR ON ENTROPY
da
@oldturkey03 probably going to be a fet on the 12v rail, but why anyone would ask on here to get advice and the give up is mind freezer
da
@tech_ni that would make sense. Do you know if that is a common thing with the One S? Checking it and even replacing it should not be to bad and probably cheaper than a new Xbox :-)
How is winter going for you? You all doing okay?
da
Mostra altri 3 commenti
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You likely have a big cooling issue. I would suggest replacing the heatsink if none of your boards are severely damaged.
Punteggio 0
3 Commenti:
if it was a cooling issue it would still show signs off life
da
@russellrepairs but where would the smoke be coming from?
da
@oldturkey03 I suspect that the cooling issue caused an overheated power supply
da
Risposta Più Utile
is there any signs of burning in this area
Punteggio 1
4 Commenti:
@tech_ni looks clean to me 🤣
da
@strongbow maybe slight corrosion around the retimer lol
da
@strongbow @tech_ni the reason why it can't work is because there are no lines between the components.
da
@oldturkey03 I didn't notice that lol
da
It could be an over heated system the chip might be fried 😬 I hope now but get it checked out
Punteggio 0
Aggiungi la tua risposta
Frankie Vaughan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 75
