does not turn on. even with pressing both buttons.
i was biking with my headphones when it started to rain a bit. when i came home i turned them off not thinking about the rain and tried to use them some days later, and they did not turn on. can i do anything?
Questa è una buona domanda?
1 Commento
If headphones aren't waterproof or water resistant, water most likely seeped in and might have caused problems. Search for disassembly procedures so you can examine for water intrusion then wipe off remaining moisture and lay out parts either in a gas oven with only the pilot light for warmth, over a furnace or water heater or out in the sun. Any method for warm heat to dry out remaining moisture for a few hours or overnight then reassemble and recharge. Canned air can be used to help blow away moisture too.
da F Dryer
