white screen after repair
I tried to change my nephew's iPod Touch 4G screen with a new one, and after replacement I got that white screen. I tried all solutions suggested here, but none of them works. It seems the volume up and sleep buttons are not working, and the iPod only responds to Home button. When you press it you get the white screen, and if you hold it for some seconds the voice recognition system works, but that´s all. iTunes detects the iPod, but it says that is protected by a password so it can´t connect.
I even tried to completely drain the battery, but after 10 days I charged it again and I got same result: after some minutes charging, I got white screen when pressing home button.
I will appreciate very much any suggestion. Thanks in advanced.
Questa è una buona domanda?
4 Commenti
it sounds very much like you either haven't connected all the flex cables properly or have the wrong part. Did you look at John's suggestions ??iPod white screen after repair the screen..
da pollytintop
Yes, I looked at John´s suggestions... I triple checked all connections and everything seems to be ok. Is there any way to "bypass" the password when connecting to iTunes? Thanks.
da madawaska
@madawaska I updated the link with some more information a few minutes ago, you might want to look over my post.
da Country Computer Service
Thanks John, that could be the problem. What it makes me feel worried about buying a new screen is that it seems that reset or reboot works for all of you, even if you get white screen again. In my case, nothing happens when you use the home / volume up / wake up buttons. The volume buttons works cause volume level changes, and home button also work.
da madawaska
