Salta al contenuto principale
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460).
24 Domande Visualizza tutte
Adhesive for iPad Pro 11" 2nd/1st Gen compatible w/ iPad Pro 11" 3rd?
I can't find adhesive for the iPad Pro 11" 3rd generation anywhere. I would like to know from an expert if the iPad Pro 1st/2nd gen's adhesive ALSO works with the iPad Pro 11" 3rd generation. If not, are there any alternatives for adhesive that is just as trustworthy?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
There are some minor discrepancies between the two, so it is definitely not an identical match. You may be able to adapt one to the other since the housing is the same overall footprint. But some of the ledges on the inside do not match exactly.
I did find adhesive for the third gen at Mobilesentrix, but they only sell to businesses, and it comes in a ten pack. So that may not suit your specific needs. Otherwise you can use Tesa tape, but you'll need to cut it yourself. Which is quite a bit more time consuming, and the seals will not be as precise.
Immagine Tesa 61395 Tape
Prodotto
Tesa 61395 Tape
$5.99
Punteggio 1
Aggiungi la tua risposta
Sky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 53
