Salta al contenuto principale
Guides and repair information for Sony speakers.
129 Domande Visualizza tutte
Charging/DC internal barrel broken on SRS-BTX300
The charging / DC supply barrel within the speaker has broken rendering the speaker unusable.
I have dis-assembled the unit and the socket in question can be seen in yellow on the attached images.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
The best thing you can do here is measure the height and width of the jack and type into eBay or Amazon (your measurements here) DC in Barrel Jack and find the closet one to what you have
This sort of job requires soldering so if your not comfortable with that sort of stuff you could take it to a local repair shop that does soldering and have them do it for you:-)
You could also replace the board in the pictures
Hopefully this helps
Any questions please ask
Punteggio 2
7 Commenti:
Got a quote online of £38, which is right at the top end of what I'm prepared to pay given that you can now pick the speaker up for £50-60.
Found the relevant barrel socket online for approx £7, but I don't have the requisite soldering skill. Soldering is on my list of skills to acquire.
The white connectors on the small board appear to be removable. However I've tried to pull them off with no success and I am reluctant to force them as they might be soldered. So that rules out replacing it in one piece.
Currently trying to find a local electronic repair shop on a few local groups, but they seem few and far between.
da
@Steve Brough
Not trying to sound creepy or anything but where about are you in the world
It’s so I can try and find you somewhere local:-)
da
@hellomacos Creep 😂😂😂😂😂
da
@strongbow 😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂 😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂
da
I had thought it would reveal as much in the post. Unfortunately not. (It's my first time on here) 😂
I'm in Manchester UK. .... Thank you.
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Steve Brough sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 212
