iPhone XR freezing and restarting around 10 times a day
Iphone XR freezing and restarting around 10 times a day.
I hope someone can help me with this.
Questa è una buona domanda?
This issue has been showing up with iOS 16. You can refer to the Kernel Panic wiki page for more details, but these specific issues are likely to be software related. Every other time I have seen these sort of watchdog timeout panics, but no missing sensor is mentioned, a fresh install of the OS through iTunes has been the solution. Obviously make sure your data is backed up first, but there is likely some software conflict or bug that the phone keeps running into.
Thank you for your answer. It looks like turning off lockdown mode fixed the problem. I will test it for one day.
I turned off lockdown mode and it did not help. Updated in recovery mode and still the same but I turned off cellular data/wifi and it works fine for last 12 hours.
update:
after 14 hours problem came back, looks like factory reset is only option left to do.
no crashes at all since I restored it to the factory settings, thanks for your help.
@voltix That's awesome, Damian! Thanks for letting us know; we'll remember that this worked when the same issue comes up again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 230
