Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
329 Domande Visualizza tutte
How big a drive can an 27” late 2012 handle?
Hey all
How big a drive can an 27” late 2012 handle? Can i go bigger than a 256GB?
If yes, any suggestions to what drive i should use? I’ve ordered this - https://beetstech.com/product/solid-stat... - but bigger would be great.
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sorry to tell you this is not the largest drive for your system. This model supports ether the Apple custom Samsung AHCI drive like this one 768GB or the slightly larger OWC 1TB Aura 6G SSD.
So I would contact BeetTech to alter your order the drive you would likely want from them or go with OWC.
Punteggio 1
2 Commenti:
Thanks. Ill do that!
da
@Tony - if your set don’t forget to accept the answer - Thanks!
da
Aggiungi la tua risposta
Tony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 24
