Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
20 Domande Visualizza tutte
iMac 27-inch, Late 2012- Problem with 3 b4 slots for RAM
Hello. My Imac (27-inch, Late 2012) has the original memory (2x4GB Elpida) in slots 1 and 2. When trying to install in slots 1+3, 1+4, 2+3, 2+4 it beeps three times and the Mac does not start. Replacing the original memory in slots 1+2 with new memory (2x8GB) is successful. Can not add memory to slots 3 and 4 (old memory or new). Please advise where to look for the problem.
Questa è una buona domanda?
Punteggio 0
1 Commento:
As you can see here your system can support 32GB!
But you need the correct SO-DIMMs
PC3-12800 1600 MHz DDR3L SDRAM (204-pin)
27” iMac "Core i5" 2.9GHz
27” iMac "Core i7" 3.4GHz
da
Aggiungi un commento
1 Risposta
If you have the correct RAM, then make sure the SO-DIMM’s are properly inserted and the contacts are clean.
Punteggio 0
2 Commenti:
original memory installed in slots 1 + 2 or 1 or 2 works fine. If the original memory is installed in slots 1+3 or 1+4 or 2+3 or 2+4 or 3+4 or 3 or 4. Slots visually clean, slot 3 and 4 do not differ from 1 and 2. Maybe the problem is in slots 3 and 4 ?
da
@Олег Б. - Then the RAM slot is damaged.
da
Aggiungi la tua risposta
Олег Б. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 162
