Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
Screen burn/ghost images on dark backgrounds.
Hi all, I've had a panicked message this morning from a customer. She had purchased a used iPhone 13 and has noticed that she can see "someone else's apps behind her screen". She forwarded a video but it's hard to make out.
When the screen is dark (not off) she can see faint app icons "behind her apps". I'm thinking screen burn but she is concerned that there is some sort of virus or malware.
Unsure of device age and previous usage as I haven't seen the phone yet.
Any advice would be greatly appreciated
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
At the moment I think it’s safe to assume that it’s not malware, malware usually does much worse thing and malware is very rare on iPhones
Also burn in is quite uncommon on iPhones that have Original displays,more common on 3rd party displays but still quite uncommon
what I think the issue is most likely to be is a dislodged display connector
It could also be debris but I have seen this happen on iPhones and iPods when the ether the display is damaged, connector isn’t seated properly or the connection has debris and needs cleaned with isopropyl alcohol
Might be worth trying the above before replacing the anything ,it’s entirely up to you:-)
Hopefully this helps
Any questions please ask
Punteggio 1
4 Commenti:
Hi, after seeing the device I confirmed it was burn in for my customer.
Her initial message made it sound like she could see another, fully working set of apps behind her own when viewing on a dark background.
Upon inspection it was only 2 app icons (telegram and Viber) that were present and in the same location while using the device in various iOS functions.
Thanks for your help
da
@dangerw1ll
Your most welcome
Glad you got it all sorted out:-)
da
@dangerw1ll must’ve been a bargain basement screen was it? I’ve replaced phone screens for years and not seen one iphone with screen burn, only dreaded Samsung.
da
@strongbow
that’s exactly what I was thinking ,iv never seen it on a iPhone ,only ever Samsungs
da
Aggiungi la tua risposta
iRepair sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 856
