Salta al contenuto principale
First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Domande Visualizza tutte
Dropped wifi iPad cannot charge battery
I dropped my wifi iPad damage the ear phone side. went run out of battery, I cannot charge battery at all.... any solution or what parts i need to change? tq
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Risposta Più Utile
I would hope it is just the dock connector, it would be a bit odd as it is dead centre inside the ipad but it is solely responsible for bringing the power in.
Punteggio 1
it could be the dock connector or another guess would be that maybe the battery shifted slightly and the contact points arent making contact anymore? or maybe the dock connector cake loose off the logic board?
Punteggio 1
I dropped mine too. Now I have to plug and replug the power cord just right to get it to connect and charge. I do get it after multiple tries but its annoying. I think I'll change out the doc connector to see if it fixes.
Punteggio 0
My battries some times shows getting charge however after 8 or 10% , it get totally discharged and then does not get charge, nor it shows any sign of charging. Any solutions.
Punteggio 0
Aggiungi la tua risposta
loh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,114
