Salta al contenuto principale
Il Sega Genesis (conosciuto anche come Mega Drive) è la console videogame di maggior successo di Sega fino ad oggi.
Power switch replacement, is it easy?
so i have two Genesis model 1 consoles and one has a very stiff power switch and the other console doesn’t work but the power switch is very easy to slide. So I want to swap the power slide switch but I can’t find any videos about this. However, I’ve seen a photo of one that was removed but the guy that took it off said he broke it and in the photo there was a spring beside the switch. I guess I just want to know if I desolder the switch, is it going to just fall apart on me?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
So I no longer need to worry about swapping the power slider switches, I bought some lithium grease and worked it into the slider switch and now it slides like butter.
Punteggio 1
Risposta più utile
It could be a build up of dirt causing it to be stiff. I’d try cleaning it first. Very old machine so greasy fingers over time could of clogged it up.
Punteggio 2
1 Commento:
Yeah I used some contact cleaner and it helped a bit but still too stiff when the case is put together. I’m going to try some lithium grease first (being delivered today) and see if that helps. But if not, I wanna try and swap them.
da Condividi
Aggiungi la tua risposta
Kevin F sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 30
Tutti i Tempi: 1,258
