Salta al contenuto principale
Lo smartwatch Apple di sesta generazione, con connettività cellulare opzionale, rilasciato il 18 settembre 2020.
Does the Apple battery come with a receiver coil?
My apple watch has not been charging. I bought a new charger to no avail. I'm planning to replace the battery. Does the battery have an inbuilt receiver coil? or do i have to buy that separate? Where is the receiver coil for the watch? I'm not sure which of the two (battery or receiver coil) is working.
Many thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Trisch Varela, if you order a replacement battery, you get the replacement battery. It’s not available in the iFixit store, but can be found all over the interwebs.
The wireless coil is a “separate” part, it’s encased in the back cover and connects via the flex.
Punteggio 2
4 Commenti:
Sincerely appreciate your prompt reply. What is the wireless coil encased in the back cover called?
da
@geirandersen
da
Trisch Varela, It’s not really called anything, as it’s all the back cover
da
@Geir Ove Andersen Thank you very much!
da
Aggiungi la tua risposta
Trisch Varela sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 146
