Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
778 Domande Visualizza tutte
Identify missing MB resistor on early 2011 MacBook Pro
I got this macbook pro for free, It was working fine before one of the display resistors blew up on me, and I have no idea how to identify what type of resistor it is. I provided a photo of the missing resistor.
Any help would be appreciated, I spent a decent amount of money fixing this thing up and it would be a pretty big loss if i couldn't fix it lol.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The 2011 MBP 13" logic board is the 820-2936. The component to replace is inductor L9004.
Description: FERR-120-OHM-1.5A
Size of the component: 0402-LF
You could harvest this part from many Mac donor boards. Good luck :-)
Punteggio 3
2 Commenti:
Thank you so much! Just to make sure, is this the correct component? I just wanna make sure I don't buy the wrong thing
https://www.digikey.com/en/products/deta...
da
This is not a resistor, it's an inductor. Looks the same but different part it's a ferrite component, Contact the guys at Digikey with the specs I gave you. This component is on the 3.3v lane that gives voltage to pins 2-3-4 of the screen connector (PP3V3_LCDVDD_SW_F).
da
Aggiungi la tua risposta
Chase Simering sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 80
