Salta al contenuto principale
Informazioni sul dispositivo e sulla riparazione per i portatili Dell XPS 13 modelli 9343 e 9350, entrambi rilasciati nel 2015.
Battery status idle, not charging after calibration
Hi, I bought an Ifixit battery replacement for dell xps 13, replacement went well, first test successful, battery was charging with 130Wh AC adapter.
After recommended battery calibration, full charge and complete discharge by the computer, the battery is not charging anymore.
bios tells battery charging status: idle, health status: excellent, no power is transferred to the battery
I am left with 2% battery life in the new one.
Switching ac adaptor does not help.
I put in the old battery again, which is charging with the mentioned 130Wh adaptor, but doesn’t hold capacity….
Is there a known solution for this situation?
Questa è una buona domanda?
Punteggio 1
3 Commenti
I have the same problem.
After fully changing and draining the battery, it now stays at 0% charge. (It was supposed to turn of at 5%)
Dell diagnosis say the charger and battery are fine, health is excellent.
Any recommendations?
da
Changing the CMOS battery would have reset everything so your only option I guess is IFIXIT Contact Customer Support.
da
please i also have the same issue.they said i should charge the battery to 10% before i can update the bios but laptop too isn't charging
da
Aggiungi un commento
1 Risposta
Risposta più utile
Updating the BIOS and drivers may help:
https://www.dell.com/support/home/en-nz/...
Diagnostics could be run from
Did you use this method to recalibrate?
https://help.ifixit.com/article/265-batt...
Are you sure the charger is the correct one for the DELL laptop?
Maybe you missed a step in the calibration? Perhaps try it again?
That system is about 7 years old. Have you replaced the CMOS battery recently?
Sostituzione gruppo schermo Dell XPS 13
Far right centre in photo. Black and red wires to coin battery enclosed in black heat shrink plastic.
(Repeating myself here) You could run the Dell Dignostics ( number 12 in list & 15 reset BIOS to default):
https://www.dell.com/support/kbdoc/en-nz...
Also you could look in the Service Manual pdf:
Let us know how it goes.
Punteggio 1
2 Commenti:
Tried all recommended actions, no change at all, ifixit replacement battery is not charging
da
Hi@benbretsch92610
da
Aggiungi la tua risposta
Ben Bretschneider sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 2,409
