Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
Not switching on after fall
My son's Switch Lite fell off his bed and now it won't switch on. There's no apparent physical damage and I can't see any obvious loose connections. It has plenty of battery.
Anyone got any suggestions for what it may be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
does it make any sounds when the buttons are pressed if it does it could be the screen, other than that there are various reasons that could cause it like cpu being damaged, but its nothing anyone can diagnose online
Punteggio 3
9 Commenti:
Thanks for replying.
No, no sounds. Fully dead. That is why I thought a loose connection.
Sounds like it could be just about anything, then. I was hoping that there may be a couple of likely candidates for the Switch Lites. I think I'll try a full tear-down and see if anything helps.
da
@davidartley do you have a multimeter ?
da
@davidartley in beep mode check the capacitors around the m92 chip to check for shorts, put the red probe on a ground like on top of the charge port and check the caps with the black probe, if any beep on both sides let me know
da
Excellent, thanks. I will try this at the weekend.
da
Mostra altri 4 commenti
@tech_ni i found four shorts on two separate points.
i have in ingress 0.14A at 5V
Punteggio 0
3 Commenti:
I don't think they're shorts. I'm sure there should be continuity through those components.
da
since you only get 5v then its more than likely m92 thats the issue as it controls the 15v. remove it and check again
da
@nige56 there is only meant to be continuity through the coil not shorted, as the caps above m92 are marked red aswell
da
Aggiungi la tua risposta
David Artley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 239
