Salta al contenuto principale
Guida di riparazione e documentazione per il Google pixel 6a con il 5G. Lanciato a luglio 2022.
replacement screen has a green hue
after replacing the screen with the official replacement from ifixit, I get a green hue when brightness is set to >70%.
I'm not sure what's wrong and I don't see any obvious way of re-calibrating this.
is there a tool or anything I need to run after screen replacement to re-calibrate colors? or is it something I might've done wrong during the installation?
any assistance would be appreciated.
Thanks.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta Più Utile
You can’t really do anything wrong, must be one of the easiest replacements ever. Disconnect and reconnect the screen making sure the connector is seated properly. If it’s still the same I’d ask for a replacement.
Punteggio 1
2 Commenti:
ok thanks for the sanity check, i'll try re-seating the screen connector later and ask for a replacement if there's no change.
thanks again!
da
Was it a connector issue, or did you end up getting a replacement? I glued everything back together before realising the issue (hey, it was bright light where I was working!).
Also: Pixel 6a replacement screen has a green hue
da
Aggiungi la tua risposta
Hugo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 532
