What's the battery type?
What's the battery type? Triple A? I can read ni-mh 1.2v 1230 (mah?) thanks
Questa è una buona domanda?
Hi Andrea,
If you check out the Battery Replacement guide on the device page, it calls out the battery used.
Two new batteries. AAA size Ni-Mh with tabs. Originals were suppo 700mAh, I replaced with 900mAh.
That same guide includes a link for replacement batteries that match the description, only they're a bit higher capacity, 1000 mAh rather than the 900 in the guide.
If yours are indeed rated at 1230 mAh, these would work but would have slightly less capacity than the old ones. You shouldn't have too much trouble locating exact replacement if you want to match what you have, though.
Good luck; let us know how it goes!
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 38
Tutti i Tempi: 324
