Salta al contenuto principale
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
62 Domande Visualizza tutte
controller works fine untill fully assembled or squeezed
im trying to service my 2 xbox elite 1 controllers.
both had slight stick drift, but worked fine otherwise.
i replaced the case on one of them because the rubber was peeling off.
well now i have both of them torn down. and when i test them with batteries and no face plate. they work fine. but if i screw down the face plate it dies, and wont turn back on. same if i squeeze it. it turns on when i plug in a usb, but will also die when compressed.
the batteries are making full contact at all 4 points. and i tried a rechargeable pack that only touches the 2 metal pins that go directly to the circuit board. same result.
any form of power dies if the controller is compressed. ive been messing with these on and off for 3 days, and im out of ideas. does anyone know what i might have done wrong.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
of course id would find the answer after i broke down and asked for help.
the rear pcb for the paddle buttons was installed incorrectly. causing a short when compressed.
controller works now that i fixed that
Punteggio 0
Aggiungi la tua risposta
Mitchell Herron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 141
