Salta al contenuto principale
Electric trimmer for grass edges and confined spaces. Also known as a Strimmer.
Motor slows down and stops
The motor gets hot and stops in a few seconds. The commutator has burn marks and beads of metal(?) alongside it. I have measured the resistances between each adjacent segment on the commutator, they are all between 3.5 and 4 ohm each. The brushes seem to be OK. Does the insulation break down? I tried cleaning it up but it goes bad the same way when turned on for a few seconds.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@alanport yes you will need a new one. the wires are insulation coated. It gets hot and melts and shortens out. There are places that rewind those but the cost will most likely exceed the cost of a new motor
Punteggio 3
1 Commento:
Thanks, no surprise really.
da
Aggiungi la tua risposta
Alan Thurbon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 195
