Salta al contenuto principale
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
550 Domande Visualizza tutte
Is Craftsman riding mower known to leak gas into crankcase?
Is this a common problem with Craftsman Riding Mowers?
solenoid does not completely shut off the gas and so it allows a siphon action to empty the bowl into the intake manifold. The raw gas then leaks down the cylinder wall and into the crankcase.
Questa è una buona domanda?
Punteggio 0
1 Commento
Yes it’s a Briggs & Stratton in a craftsman mower
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Patty,
Which engine is in your riding mower? I'm assuming it's a Briggs & Stratton.
I work on a lot of B&S motors (small engines is my main hobby), and even though we don't have Craftsman in Norway, the mower brand doesn't really matter as it's the engine in question. Not many manufacturers produce their own engines.
I have never come across one B&S engine that is more prone to leaking gas into crank case than others.
If the solenoid isn't closing 100%, then it needs to be replaced. They are very cheap, and swapping them out is really simple.
The only "specialty" tool you'll need, is a very thin wrench to undo the solenoid.
Punteggio 3
4 Commenti:
@geirandersen
Welcome back!
It’s great to see you back as it’s been a while since I have seen you about the answers forum!
Keep up the good work and welcome back:-)
da
@hellomacos Hi there :)
It’s good to be back again! I’ve been so busy, life just got in the way. But I realized I need to start taking care of myself, and fixing stuff is heaven to me.
da
@geirandersen
That’s good that your doing better:-)
Fixing stuff is just so much fun!
Welcome back:-)
da
@geirandersen I concur with the comments left by my colleague @hellomacos Good to see you back and yes, I hear what you are saying about life. My issue as well ;-)
da
Aggiungi la tua risposta
Patty sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 362
