Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
Power Button doesn't work.
The MacBook doesn't work when I press the power button, but when I unplug the battery and plug in the charger it turns on. So I think the power button is damaged. Can anyone tell me where I can get a power button and how to change it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The power button is part of the keyboard so you must replace the whole keyboard. A replacement keyboard for your MacBook Pro is easy to find on many places on the web just search for "A1278 US 2010 replacement keyboard", you should pay $30 for a new one. To replace the keyboard you must remove the logic board, the DVD drive , the backlight layer and + - 80 small philips screws. You should order the keyboard and the backlight layer cause the keyboard backlight is often damaged during removal. Check on youtube for a keyboard replacement tutorial.
Punteggio 3
Aggiungi la tua risposta
Rodrigo Carvalho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 55
