Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
My PS3 disc is stuck, how can I get it ejected?
I got the dreaded YLLOD with a disc still inside.
Yes, I have seen the help here about the fan cycle. It doesn't work for me—it just goes to yellow. Is there any other way apart from dismantling my PS3?
Questa è una buona domanda?
Punteggio 20
11 Commenti
This question was migrated from http://meta.ifixit.com/Answers.
da
I had to turn it upside-down, tilt it down, hold the power button and the eject power at the same time in order for it to give me my dvd. Pretty much put my PS3 into submission.
da
http://ccm.net/faq/4912-ps3-how-to-force...
It worked perfectly for me...... plug out the PS3 keep ur finger on the eject button and plug in ans switch on .......whammmm!!!!!! there come ur DVD ...out... its easy...
da
I've tried all of the above but it hasn't worked for me
Im wondering when i get thisYLod fixed. Am i able to Still keep the DVD once its repaired?Please respond ASAP
da
I too had the same problem with a stuck disc I tried all the techniques to remove the disc but I figured with my playstation having the ylod anyways I figured what more damage could I do by removing the blu ray drive and opening it myself be prepared if u decide to attempt this there are about a dozen or so screws holding everything together
da
Mostra altri 6 commenti
Aggiungi un commento
18 Risposte
Risposta Più Utile
If you havent figured it out yet, this is what you do. Turn the main power switch off in the back. Next, hold down the eject button and turn the switch back on. The fan will run high and it will eject your disc. May have to do it a couple of times. Worked on the second try for me.
Punteggio 21
13 Commenti:
thx that worked great
da
Hey man. 3 years later and this worked for me. I just registerd to say thx :-)
da
I tried don't work
da
thanks got my gran turismo 6 disk back out first try
da
How to eject jammed CD disc of PS3 Slim - Fast & Easy way with 1 hand !
https://www.youtube.com/watch?v=iStLmErG...
da
Mostra altri 8 commenti
If holding the eject button and pressing and HOLDING the power button till the power light is green does not eject the disc, It may be the drive is DUFF or just jammed for some reason.
THIS GUIDE should be your next option.
Pull the drive out and see if there is anything obvious.
PlayStation 3 Yellow Light of Death (YLOD) Fix Kit may also be worth consideration.
Immagine Fix kit for PlayStation 3 (PS3) consoles with the "Yellow Light of Death" (YLoD) failure.
Prodotto
$24.99
Punteggio 4
2 Commenti:
How to eject jammed CD disc of PS3 Slim - Fast & Easy way with 1 hand ! https://www.youtube.com/watch?v=iStLmErG...
da
Thanks this worked
da
sometimes manual and force eject don't work . I've made my own way of ejecting it . you get 2 discs and force them in to get the 3rd out just make sure bottom one doesnt go in more than top .
its worked every time. don't waste your money.
Punteggio 2
1 Commento:
My little one pushed 3 DVD's into PS3 and I did get all out by pushing in the 4th one. Thanks
da
Definite fix.
Turn off system.
Hold eject bottom down and turn it back on.
This will put your disc back into PLSY position.
HERE'S THE TRICK THOUGH.
Hold another disc just slightly in the disc tray, you should bring up solid on the disc inside the system.
Hit the eject button, wait half a second and then take out the disc you're holding. It should hold the tray open long enough for the regular eject.
Should come out then.
I tried this 4 times before it worked.
Punteggio 2
1 Commento:
Worked first time cheers mate
da
Turn off the PS3 by removing the power cord.
Put your finger on the Eject button and hold.
While keeping your finger on it, turn on the PS3.
Wait for 10 to 30 seconds (during this time, the fan will be louder than usual) and release.
Your game disc should be ejected.
You may have to do this a couple of times
Punteggio 2
I did what you said guy none of them works, i think i have a problem in my ps3 , so here's what i did i pressed eject button then entered edge of new CD game in case there's something not opening while ejecting Process & it's worked."
hey thanks btw (y)
Punteggio 1
3 Commenti:
Best troubleshooting trick ever! My son was devastated when he realised his 2 year old sister had stuck multiple DVDs in, fan trick did nothing. Placing 1 disc in part way in and pressing eject got 2 discs to come out, pressing eject got a 3rd disc out. THANK YOU!!!
da
the ps3 he is useing is out of date
da
Probably a dead blu-ray drive.
da
http://www.playstationlifestyle.net/2011...
Punteggio 1
1 Commento:
This method details a way that you can use a secret compartment. It's also detailed here: https://support.playstation.com/s/articl... -- it's the way that worked for me
da
Yes, will let you know which one is successful
Update (03/05/2017)
I tried a couple ideas, what worked for me was turning the switch off in the back. Holding the power and eject same time and switching the back power on again.
Punteggio 1
The most effective way to get your disc unjammed from the disc tray of a PS3 is to use a bar burrito card, a largely effective tool in maneuvering the disc out of the disc tray.
Punteggio 1
You should press both buttons at the same time, you will hear some beeps and hopefully it will spit out the disc.
Punteggio 0
The answer from MICHAELPALACIS(below) was absolutely spot on. I removed FOUR DVDS from the machine.
Thank You!
Sometimes manual and force eject doesn't work . I've made my own way of ejecting it: You get 2 discs and force them in to get the 3rd out. Just make sure bottom one doesn't go in more than top .
This worked every time. Don't waste your money.
Punteggio 0
4 Commenti:
How to manually eject a disc from PS3 slim: http://youtu.be/C-lfUEUNIS8 I watched this video and was the only thing that helped for me
da
How can I ever get two additional discs in??
There seems to be something blocking it.
Btw; how can i be sure that there is a disc stuck in it? Maybe there's another problem just preventing me to insert a disc.
When I want to play the system says there's no disc..
da
I solved one part of teh matter. Dismantled the PS and part of the blueray player and managed to get the disc out.
However, now still I can't get a disc in anymore. there's a white pin or something blocking it.
Any ideas how to fix that?
Thanks!
da
I also have a white pin blocking my disc to be inserted in my console how do I fix this.
da
swithch off the console unplug it. Again plug it in and before switching it on keep your finger on the power botton ( keep it there till your DVD is ejected) NOW SWITCH IT ON...the player will run in high speed and after a few seconds DVD will be ejected. Enjoy.....
Punteggio 0
On the underside of the playstation where the screw for hard drive is the cover is bigger and pops out leavening one hole with your hard drive screw and and anothef with no visable screws if you put your screwdriver in this hole and turn it will manually eject may need to turn upside down to get disk in right position worked for me when fan test would not unfortunately my son had also put 2p in it with the 3 stuck discs so I had to dismantle an yway
Punteggio 0
If you can see the disk use a tweasers to grab it then hit the eject button
Punteggio 0
1 Commento:
Be sure the tweezers do not conduct energy, or you could nuke the PS3 and yourself.
da
Yes because you can open the ps3 and just by using a screw driver, and u can see everything in it
Punteggio 0
Don't they have the screw on the bottom for ejecting the disc I remember this when I used to fix the YLOD.
Punteggio 0
Press and hold the power and eject button at the same time, after confirming the blu-ray drive is not at fault. If this doesn’t work, replace your fan and try again.
Hope this helped. This is what I did for my blinking red light problem, and I finally have my Red Dead Redemption: Undead Nightmare disk back.
Punteggio 0
Yes the screws on the bottom undo all of them and the the disk drive has screws to and undo them to then it should be undone enough that you can just grab it out
Punteggio 0
Aggiungi la tua risposta
ronan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 287
Tutti i Tempi: 185,156
