Salta al contenuto principale
La variante solo Wi-Fi dell'iPad di quinta generazione è stata rilasciata nel mese di marzo del 2017. Disponibile con tagli di memoria pari a 32 o 128 GB, presenta un display Retina da 9,7" e il processore A9 a 64-bit.
Can you remove the little circle around the home button?
picture So im repairing my iPad 5 rn and i saw this little plastic ring around my homebutton, i decided to remove it as its just a piece of rubber and plastic, but maybe it served a purpose? lol. Does anyone know if this is bad or can i continue?
Update (08/30/2022)
This, teh left (rubber was first atteched to the back of the plastic one and surrounded the homebutton together.)
Questa è una buona domanda?
Punteggio 1
3 Commenti
Can you add a picture of the object?
da
@Traxced
We can’t see the images as they are a comment
You need to add them to the original question
You need to edit the question then add them. :-)
da
@hellomacos yep i noticed lol, i did it now!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If you mean the gasket? Then you will likely need this. It helps to mount the button to the display and stabilize it. It also provides some very minimal protection against liquid entry.
Immagine Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4.
Prodotto
iPad 5/6/Air 2/mini 4 Home Button Gasket
$6.99
Punteggio 5
Hi
From what the photos show that is a gasket
This isn’t necessarily needed but it helps keep dirt out
You could use some light adhesive on it or order a new one
But as I said your iPad should work without it but it’s recommended that it’s there
Hopefully this helps
Any questions please ask
Punteggio 2
Aggiungi la tua risposta
Traxced sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 312
