Salta al contenuto principale
Il controller wireless Xbox 7MN-0001, prodotto da Microsoft Corporation, è il controller più utilizzato per la console di gioco Xbox e può essere utilizzato anche su PC.
127 Domande Visualizza tutte
after the 20 sec connect pc it dısconnects and starts blinking
i m connecting it with blothoot i tried to connect my phone and it worked but now i m trying connect pc but it doesnt
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You will most likely need to update the firmware. To do that via PC:
Download the "Xbox Accessories" app from the Microsoft Store, connect your controller via USB to your PC and you should get the option to update the firmware.
Punteggio 0
4 Commenti:
i udated it and i updated bluetooth and i recconnect gamepad and restarted pc i dont have warranty in the box there is a paper which says you can connect with bluetooth
da
@alikerem uzun Yes you can connect with Bluetooth, but to update the firmware on the controller, you need to use USB. Since you updated the controller firmware, has there been any changes?
da
no i updated computers bluetooth and first of all i updated gamepad with cable
da
@alikerem uzun So are you still having the same issue? If so I might have another Idea
da
Aggiungi la tua risposta
alikerem uzun sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 40
