Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
90 Domande Visualizza tutte
right speaker broken? all coreaudio is played through the left speaker
yesterday my right speaker suddenly stopped working and all the audio is being played through the left speaker (L and R channels, checked for it with audio midi setup utility app). restarting PRAM, reseting coreaudio with terminal didn't help. does it mean my right speaker is just dead?..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
It could be a bad speaker like you said but there are something things you can do to confirm this
Check the balance in your sound settings, try playing something and sliding the sider for left and right about
Try reseating the speaker connector
(Here’s a guide Sostituzione altoparlante destro MacBook Air 13" Retina Display 2019)
Make sure there is no metal debris on the speaker itself or the cone or membrane
If none of these things work the speaker most likely needs replacing
Hopefully this helps
Any questions please ask
Punteggio 2
Aggiungi la tua risposta
damian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 25
