Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
93 Domande Visualizza tutte
Changing the single sim card reader to dual sim card for iPhone 13
My iphone 13 is a single physical sim card reader and an e-sim version, is it possible to change the single sim card reader to a dual sim card reader, the one that is installed in the hong kong variant the dual physical sim? is there a software lock to this? will it be detected by the phone and automatically converted to a physical dual sim variant without tinkering some things in the hardware or software?
Questa è una buona domanda?
Punteggio 2
1 Commento
My iphone 13 is a single physical sim card reader and an e-sim version, is it possible to change the single sim card reader to a dual sim card reader, how ????
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Should be easier than 11 pro which required a lot of soldering. Just replace the sim tray and reader.
Punteggio 2
12 Commenti:
I'm worried if there is already a software lock if we replace the sim card reader on the ip13
da
@Yan Mar Trading There was never a software lock, on iPhone 11 there was boardID resistors and eSIM power you need to modify, the eSIM seem to be included in the removable reader from 12 and above.
da
@tomchai so it is just a remove and replace process. thanks for the answers
da
@Yan Mar Trading according to the repair video, yes, but I'm not 100% sure, you can try, worst case you put the original one back.
da
@tomchai i have search youtube but the only video I found was with the ip12, the Hugh Jeffreys video
your right, if things don't work out I can just put the original one back on, I was just hoping somebody did it already and share his experience
da
Mostra altri 7 commenti
Yes you can do this. I have an iPhone 13. US model, I switch sim readers, both sims work fine, there’s a small glitch when connecting calls but it’s nothing to worry about.
Please be aware though, using 2 SIM cards from the same provider, sometimes it will only pick up on one sim, not the other, so best use 2 different service providers, 5g works fine aswell. You can run 2 WhatsApp’s no problem and can alternate calls.
Another bonus is that you can have automatically tex or call from any sim if you separate your call lists into 2 sections using the list feature in the phone book,
God bless you all.
JP,
Apple service engineer
UK based.
Punteggio 2
Done thanks to @tomchai video posted I have replaced the SIM card reader with the dual sim version bought in China.
Software swapped from eSIM to dual SIM automatically
I am using now the phone with 2 Sim, one European and one Vietnamese since last July 2022 without any problem.
Punteggio 2
Aggiungi la tua risposta
Yan Mar Trading sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,692
