Salta al contenuto principale
Informazioni su riparazione e smontaggio dell'iPhone SE di seconda generazione, annunciato e lanciato sul mercato nell'aprile 2020.
239 Domande Visualizza tutte
iPhone SE 2020, restarting every 180s because of tg0b, board defect?
Hello Guys, i need help. I have an iPhone SE 2020, replaced screen (by me) which is now kernel panicking and restarting every 180s (has nothing to do with the kernel panicking, screen replacement was done now a year ago). It has no obvious pry damage, the mosfet by the battery connector is still in place and not moveable. With both the OEM Battery and a new 3rd party one the kernel panic keeps happening as well as the 0% battery charge thing. In the logs "missing tg0b" is stated. When starting without the dock and front camera flex attached the logs state "missing tg0b and mic1", so i suppose its a board issue? Any tips?
Update (07/26/2022)
The battery connector
Questa è una buona domanda?
Punteggio 1
1 Commento
One of the data pins looks to be pushed into the plastic but I cannot be certain. The measurements you took are okay.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
This does sound like a battery data problem. The first thing to check would be the battery connector as they are known to be problematic on this model. Check the pins have not been pushed into the plastic, if they have you will need to pry them out. The next step would be measuring the pins with a multimeter in diode mode. Also there are two fetts near the battery connector not just one.
Punteggio 1
1 Commento:
i measured the pins and got the following readings: GND for GND and 418 for the 2 big pads on the other side as well as 689 for the data pins. Ill post in another comment a picture of the connector
da
Hi Benjemiah,
The error code refers to Temperature monitoring chip on the motherboard stopped working due to no feedback from the temperature sensor it has gone to fail safe mode (restart for every 3 mins)
Punteggio 0
1 Commento:
So it is not a Battery SWI Problem? How can it be fixed?
da
See this youtube link: https://www.youtube.com/watch?v=GSH2Y-Sp...
This will show in detail the circuit board issue
This is reference to the Panic restart every three minutes with reference to Mic1 not being found
Punteggio 0
Aggiungi la tua risposta
benjemiah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 353
