Can you put a 2009 logic board into a 2012 MacBook Pro
Can I install a 2009 logic board into a 2012 Macbook Pro
Questa è una buona domanda?
So their are a few issues with attempting this. While both boards seem to have a similar layout for its standoffs, the 2012 board has several different ports for the camera, battery, Airport/Bluetooth, and Optical drive. It's also worth pointing out that if you're replacing a core component like the logic board, then you might just want to start looking for a new computer at that point as the logic board is pretty much the computer itself.
Simple answer - No!
There are quite a few physical differences as well as cable connections which are different.
There really is no benefit putting an older logic board within a newer case. Why would want to do this?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 45
