Salta al contenuto principale
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
Why isn't the power button working?
So recently I took apart my iPod Touch to replace the battery, which I did successfully and it works, but when I was replacing it and took out the motherboard because I thought that I had to. Now the connector is loose to the board, and when I manage to get it to stay in it is still loose. Does anyone know how to fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
My first (major)repair was one of these and I had this exact issue because it’s really annoying to blindly get connectors connected from behind
I find I you get the cable and remove the little bit of silver/grey tape fabrics stuff and extend the cable until it’s straight
Before you do that you need to get the logic/motherboard out and you can kind of flip it and connect it fairly easily
It’s a bit bad to explain but if you need any help just ask me in the comments and I can help you at every step of the way:-)
Hopefully this helps
Punteggio 1
Aggiungi la tua risposta
sjamesmm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 124
