Salta al contenuto principale
The Sony TCM-919 is a portable and lightweight cassette player with audio recording capabilities. This device of the 1990's is equipped with a 3-digit tape counter, microphone, and auto-shut off, and a front speaker system.
My TCM-919 player is not spinning
I put on the batteries already but when I press play or record nothing is moving but it make noises but no music from the tape and I can see the tape is not moving
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is only one way: use this guide and open the device. Switch it on. Have a look to the gears, perhaps you can see a broken rubber belt?
Punteggio 1
3 Commenti:
How can I know if the rubber is broken or not?
da
@iitoobb Step 5 picture 3 of the above guide shows the rubber belt from the motor to the spindle. That is the belt that will have to be present.
da
Thanks , I’ll try to find a new rubber belt because mine looks more loose
da
Aggiungi la tua risposta
Iitoobb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 207
